- 6 months ago
#23012
SEVENFRIDAY M3/01 Spaceship Edition
SEVENFRIDAY takes its swiss replica watches to a brand new level with the M3/01 Spaceship Edition. A seven-layer framework and 11 components develop a distinctly layered and 3d interface. Sandblasted and refined black and gunmetal gray disks form an aerodynamic Y-shaped wing, with the SEVENFRIDAY logo design prominently positioned at three o'clock.
The Y-shaped switch design cleverly accommodates 3 overlapping white discs, showing the hours, minutes, as well as seconds, read from remaining to right. A red-colored highlight at 9 o'clock indicates the hours on the left hand side, and a red arrow signifies the minutes on the correct. The seconds hand floats above the nameplate in installments of "5".
Asymmetrically dispersed decorative screws on the call enhance the industrial feel of the "Spaceship" special edition watch. Grooved black silicone cushions the actual bezel and black calfskin strap.luxury replica watches
Technical Specifications
Case Dimensions: 47mm (H) x forty seven. 6mm (W),
Stainless steel along with PVD gunmetal finish and also polished.
Bezel: Stainless steel together with PVD gunmetal finish; each inner and outer bezels are polished.
Case Back: Polished stainless steel; NFC nick embedded on the back of the world.
The NFC chip inlayed on the back of the globe may be used to verify authenticity through the SEVENFRIDAY app and authorized merchants.
Movement: Miyota 8215, 40-hour power reserve
Strap: Black calfskin and silicone
https://www.whereguidewatch.com
high quality replica watches
