- 2 years ago
#22997
Panerai Luminor Quaranta Carbotech PAM01526: New high quality replica watches to iniciación at SIAR 2024
On the International Watch Fair inside Mexico, Panerai unveils a fresh version of the Luminor Quaranta. The Panerai Luminor Quaranta Carbotech PAM01526 will be situations the public for the first time, featuring a more compact case, a bold design and style and exquisite materials.
Circumstance
The case of the Panerai Luminor Quaranta Carbotech PAM01526 is constructed of Carbotech, a material consists of carbon fiber that is lightweight and sturdy. This is the first time that the Luminor Quaranta has a Carbotech circumstance. The case has a diameter involving 40 mm and capabilities the iconic crown protection in addition to straight lugs. The matte black finish varies coming from model to model, offering each watch a unique seem. A new 30 bar (approx. 300 meters) water resistance is a highlight. The screw-down blue crystal caseback offers a view of the movement. luxury replica Watches
Dial
Typically the dial of the Panerai Luminor Quaranta Carbotech PAM01526 is usually matte green, in keeping with the particular “sandwich” style, enhancing detail and legibility. White Super-LumiNova X1 on the dial as well as hands ensures legibility inside dim light. As is typical connected with Panerai watches, the small mere seconds subdial is located at on the lookout for o'clock, adding to the functionality and also beauty of the dial.
Movements
The Panerai Luminor Quaranta Carbotech PAM01526 replica swiss watches is definitely powered by the automatic P. 900 calibre. This movements, despite its versatility, is well known for its slim dimensions. Using a diameter of 28 millimeter and a thickness of several. 2 mm, it is one of many slimmest movements in the Panerai collection. Key features add a three-day power reserve, a balance tyre that vibrates at twenty eight, 800 vibrations per hour, and also a bidirectional rotor. A stop-seconds device allows for precise moment setting. The open caseback allows a glimpse in the complex mechanism.
Strap
Often the Panerai Luminor Quaranta Carbotech PAM01526 comes with two straps options featuring the impressive PAM release system. The first is a military green plastic strap, durable and comfortable to embellish, the other is a brown calfskin strap, reminiscent of Panerai's traditional designs. Both straps have a very brushed titanium buckle together with DLC coating, ensuring attractiveness and sturdiness.
replica Zenith PILOT Porter
replica U-Boat Flightdeck Watches
best replica watches
Brand Panerai
Model Luminor Quaranta Carbotech
Reference PAM01526
Case Substance Carbon Fiber
Aspect Diameter 40 mm
Water Resistance 30 bar (~300 m)
Dial Matte green with white Super-LumiNova® X1
Strap/Bracelet Military environmentally friendly rubber strap with dark brown calfskin strap. PAM simply click release system.
Movement L. 900
Movement type Programmed
Power reserve 72 hours
Regularity 28, 800 bph (4 Hz)
Functions Hours, mins, small seconds, date
Circumstance
Dial
Movements
Strap
Brand Panerai
Reference PAM01526
Movement L. 900
