#22978
For many online betting enthusiasts, sportsbooks are a familiar territory. Particularly renowned for their football betting options, they have established a prominent presence in the Asian market. But have you explored corner kick betting yet? Let's delve into everyday winning soccer tips together!
What is corner kick betting?
When it comes to soccer betting, the typical focus revolves around three basic bet types: Asian handicap, Over/Under (Total Goals), and European handicap. However, there are numerous additional betting options, among which corner kick betting has been gaining traction among players.
Corner kick betting operates similarly to other subsidiary bets like yellow card betting, halftime betting, or kickoff betting. Each of these supplementary bets holds its own merits and attractive payout rates. When engaging in corner kick betting, the emphasis isn’t on the overall match outcome or the final score but rather on the number of corner kicks taken during the game.
Additionally, there are various types of corner kick bets, such as predicting which team will earn the first corner kick or which player will take the first corner kick. Hence, it's unnecessary to focus on goal tallies or match results. Instead, the attention should be on the quantity of corner kicks.
Why consider corner kick betting?
Each match will have different corner kick odds, allowing you the freedom to select the most suitable bet. Moreover, this is one of the easiest subsidiary bets to analyze quickly. The win or loss result is solely based on the number of corner kicks in the match. Therefore, there's no need to worry about manipulated outcomes aimed at deceiving bettors.
You don't have to place corner kick bets well in advance of the match; many sportsbooks offer live betting options, such as second-half corner kick bets or wagers on the last team to take a corner kick. Compared to other subsidiary bets, corner kick betting offers significantly higher payout rates while also increasing the player's chances of winning.
Common corner kick betting options
As mentioned earlier, corner kick betting encompasses various types with different odds. This flexibility allows players to choose bets that align with their preferences and financial conditions.
Handicap corner kick betting, also known as corner kick handicap betting, operates based on the real difference between the two teams, resulting in specific handicap odds. Your task is to predict the number of corner kicks in either the entire match or within a specific half.
In essence, this bet type resembles handicap score betting. However, instead of forecasting the number of goals, the focus is solely on the number of corner kicks in the entire match or a specific half. Handicap corner kick betting is a popular subsidiary bet among many players
Corner Kick Betting in Asian Handicap
Unlike the common Win-Draw-Loss (1X2) bet, the Asian Handicap corner kick bet relies on choosing the team that will have More – Equal – Less corner kicks throughout the match.
Therefore, players need to consider this carefully. Especially, to avoid excessive losses, it's advisable not to bet on the Equal corner kick outcome. The probability of both teams having the same number of corner kicks is extremely low. On average, in every 10 matches, only 1 will result in an Equal outcome.
Over/Under Corner Kick Betting
Bookmakers determine a random figure representing the total number of corner kicks in a match. Players predict if the actual number of corner kicks will be higher (Over) or lower (Under) than the bookmaker's estimate. If the actual number surpasses the bookmaker's figure, bet on Over; otherwise, bet on Under.
In reality, this corner kick bet doesn't heavily rely on a player's analytical or predictive skills. Instead, it's considered more for entertainment and primarily based on chance. The player's winning odds always stand at 50:50.
Tips for Novice Corner Kick Bettors
Research and Analyze Team Information
This is a crucial factor determining your win or loss. Before placing bets, invest time in gathering best betting tips app and details about the teams:
Most used football tactics.
Starting lineups and substitutes.
Key players for each team.
Recent head-to-head results in home and away matches.
Recent performance and current standings.
Players' positions and their playing style. Teams with strong midfielders often generate more corner kicks.
Player fitness and recent injuries or form.
Additionally, consider objective factors like weather conditions, home or away grounds, etc.
Monitor the Match
Once you've entered the corner kick bet, continuously follow the match from its beginning. This is advantageous, especially for bets like the next corner kick or last corner kick. Typically, teams inclined towards strong attacking play will earn more corners than defensive teams.
Continuous match observation helps identify potential bets that can lead to wins even while the match is ongoing. If the match is merely a friendly exchange between two teams, there might not be many corner kicks.
Choose the Right Betting Time
During the initial phase (first half) of the match, teams play stably and evenly, with intensive attacking plays leading to numerous corner kicks. Therefore, betting on the first corner kick should favor the stronger team.
For the last corner kick bet, consider the team trailing and continuously attacking in hopes of equalizing.
In scenarios where the first half has few goals, the second half is often intense and lively. Hence, corner kicks are more likely in the second half.
Watch now: what's an asian handicap bet
This article compiles all essential information. Hopefully, after careful consideration, readers will have a clearer understanding of corner kick bets and effective strategies.
