#22775
yinruimachine.com
The glass cutting machine adopts stepper or servo motor, driver and CNC control system, and is equipped with imported cutter wheels. It has the advantages of good stability, high precision, and multiple cutters can cut at the same time, which can realize straight, irregular and circular cutting of various types of photoelectric glass and ultra-thin glass. In addition to superior configuration and performance, the machine also uses a man-machine interface, which can be intelligently optimized for cutting, which truly realizes the convenience and intelligence of operation.
This cnc ultrathin glass cutting machine is for cutting ultra-thin glass(thickness 0.2-8mm), such as optical glass, liquid crystal glass, mobile screen protector glass, touch screen glass, OGS process of ultra-glass. This machine can cut glass in to any shape by one time through CCD automatic select and position. Users can change the cutting point as they wish. It can optimize graphics and set type automatically. What's more, it is easy to operate because of typesetting and control is in same software. In addition, it can optimize the tool path automatically if user need to cut in different areas.
A glass washing machine must handle and clean glassware properly to insure usefulness. Glass washing machines are often responsible for related tasks such as collecting and distributing glass, cleaning and sterilizing glass and storing and inventorying glass. These tasks require a working knowledge of research in order to determine what items will be needed. After cleaning, the glass washing machine will store and inventory items. They must be very organized and able to keep good records.
Glass washing machine for cover lens features stainless steel air knives, soft brushes and cylinder-powered upper brushes for cleaning low-e glass, quick-change water nozzle, high-pressure pre-washing and aluminum upper bracket profile.
Glass turning machine is the machine for pulverizing glass during glass recycling process. When feeding the glass into the glass crusher, the glass will fall into a high speed rotating impeller and been crushed to several pieces. Some parts of the glass will stay near the impeller. Under the force of the high speed centrifugal, the glass pieces in different positions will crash onto each other. After several times of collision and friction, the crushed glass will drop off from the machine. The glass turning machine is with the features of small footprint, easy and safe operation, low energy consumption and noise, high output and large processing capacity. It is not only widely used in industrial area, but also commonly used in bars, hotels, etc. It can help us to break the wine bottles in time to prevent old wine bottles from been going back to the market.
The motor of glass beveling machine has a good torque, solid construction, low power consumption, suitable even for beveling and grinding of large numbers of glass pieces. The machine is made to be very efficient in the production of fine glass bevels with minimum wastage of materials and time. Glass beveling machine comes with an optional laser alignment and grinding unit. Besides, automatic glass beveling machines have the ability to cut any shape as well as a straight edge. These beveled edges can be formed into any shape possible and can also be sharp edged or not. The sharp edged bevelling machine is capable of producing unique bevel patterns that are impossible to create by hand.
With the advancement in technology, glass lazer cutting machine is highly used and recommended as they are more cost-effective and time-saving options. Classical methods like diamond scribing etc were used to cut the glass which used to result in grinding, masking and etching and other tedious processes and the output had micro-cracks and therefore required high maintenance. The high powered beam cutting directs the beam throughout the length of the beam axis and thereby resulting in creating the most cost effective and rapid speed solutions. Glass lazer cutting machine produces outputs with precisely done natural tempering edge with the highest quality as they are operated with computer-directed systems. With the advancement in optical technology, high-powered CO2 lasers with high-intensity speed is combined with surface cooling system to produce the glass and cuts of best quality & perfect fracture.
LCD glass double-sided cutting machine can meet the cutting requirements of different types and shapes of glass and mirrors, such as automobile glass, rear mirror, vanity mirror glass, wafer glass, watch glass and craft glass, decoration mirrors. LCD glass double-sided cutting machine is small and compact. It adopts cast iron work table. And it's very durable. The machine can cut both flat glass and curved glass and mirror. Adopting memory for breakpoints ensures that it can be processed in case of any break-off. The machine is easy to operate and has no special requirements for the operator. You can get started with a little training.
With glass edge grinding bevelling machine, rough grinding, fine grinding, polishing of bevel and grinding of bottom edge can be completed in one time. Processing thickness, angle and remaining thickness appears on digital display. The processing speed is adjustable with a step-less motor which offers a wide range of speed selection. Input and output conveyor adopt timing belt which can improve the transmission precision. The grinding wheels are indirectly connected to the motor by a belt to reduce vibration. It has high efficiency and precision, stable quality, easy operation and low wear.
The double shaft sealant curing machine adopts international popular static mixer reciprocating belt, and make the mix more evenly. This curing agent system is fully closed and prevent the air from exposing to agent and get solidified. Having the adjustable proportion system, added the two components proportion detection system, ensure the two component glue ratio and meet the curtain wall and insulating glass ratio requirements. Double shaft sealant curing machine adopts two filter system, and improves the mixing uniformity of two components. Sealant curing machine is equipped with high pressure pipe line safety protection device and make operation and use more safe.
