#22766
aochenrubber.com
Rubber sheet is a sheet made of rubber or cloth coated with rubber. There is a wide variety of rubber sheets in the market and finding the most appropriate one is often a tough task. Before selecting that kind of sheet you should check its length, width and thickness as per your requirements.
Technically speaking, industrial rubber is a natural polymer of Isoprene (usually cis-1,4-polyisoprene). It is hydrocarbon polymer occurring as milky latex in the sap of various plants and can also be made synthetically.
Silicone rubbers are often one- or two-part polymers, and may contain fillers to improve properties or reduce cost. Silicone rubber is generally nonreactive, stable, and resistant to extreme environments and temperatures from ? 55°C to 300°C (? 67 to 572°F) while still maintaining its useful properties.
Fluroelastomer or FKM rubber is a class of synthetic rubber designed for very high temperature operation. FKM provides extraordinary levels of resistance to chemicals, heat and oil, while providing useful service life above 200°C. FKM are not a single entity but a family of fluoropolymer rubbers. Fluoroelastomers or FKM (sometimes also referred to as FKM Viton) can be classified by their fluorine content, 66%, 68%, & 70% respectively. This means that FKM rubber having higher fluorine content, have increasing fluids resistance derived from increasing fluorine levels.
Rubber floor is a type of resilient floor, and therein lies its most obvious advantages. Like other resilient materials, namely vinyl and linoleum, rubber flooring provides a durable, easy-to-clean surface that's suitable for hard-wearing environments, such as gyms, basements, rec rooms, playrooms, laundry rooms, and utility areas.
Anti slip rubber sheet is a kind of non-slip rubber sheet. All kinds of patterns are on its surface so it looks elegant. The rubber sheet features the properties of shock absorption, noise reduction, pressure resistance, and wear resistance. In addition, it is safe, eco-friendly, water-proof, fire-proof and antiskid. What's more, it's easy to be installed and maintained.
Livestock mat is a necessary product for the benefit of all livestock and barnyard animals. Livestock is an expensive investment and many people are dependent upon them for their livelihood. Farmers and owners of livestock will want to protect their investments with barn flooring.
Cow and horse mat is useful because it does not allow for liquids to sit in bedding. Cow mats are also resistant to microbes and harmful bacteria. This is especially important for animals living in areas where a lot of bacteria could be present. They also protect cows from the inside out because they can protect against internal injuries. These horse stall mats perform really well as a cow mat option. They are antibacterial and antifungal, as well as completely non-absorbent. The rubber surface provides comfort and protection and is slip resistant.
Horse trailer mat reduces the amount of stress on horse's legs, back, and muscles while standing and at the same time offering a floor that is easily cleaned. Most trailer mats are custom cut to provide one piece, wall to wall protection from our durable, solid 1/2″ thick rubber product. Most trailer mats are custom cut to provide one piece, wall to wall protection from our durable, solid 1/2″ thick rubber product. Trailer mats provide a smooth finish on the base to resist bacteria and debris collection , and a textured, anti-skid surface on the top for maximum traction. 3/4″ thick mats are also available.
Gym rubber is installed on top of existing flooring to protect them against any damage caused by workout equipment and fitness machines. Rubber is the best material for creating a gym floor surface due to its long-lasting protective properties.
