 q54hy6
#22764
wonderful-bamboo.com
As a construction material or decorative application, bamboo wall claddings are unmatched in the style department, making it even more attractive to interior designers and D.I.Y. enthusiasts. Bamboo wall panels and woven bamboo wall coverings can be used to cover a full wall or you only cover half the wall.
Bamboo plywood is made of fine layers of bamboo strips laid in parallel order and kiln dried, sanded smooth and then laminated edge to edge to create a single-ply panel. These panels are then laminated again to each other to create multi-ply bamboo plywood free of formaldehyde emissions.
Film faced plywood is an exterior plywood used in building and construction projects. It has a special film coating on its surface made from phenol or melamine on either or both sides which gives the plywood a higher resistance to moisture, abrasion, chemical degradation and fungal attack compared to ordinary plywood.
Bamboo decking is decking made from the fast-growing bamboo plant, a family of woody grass species native to Asia, and long used as a building material. Bamboo is lightweight and robust. Decking made from bamboo can either be strand woven or nonwoven. Strand woven is known to provide greater strength.
