#22744
What Is the Difference Between an LVP Product and an SPC Product?
When it comes to choosing flooring materials, you have a lot of different options. There are dozens of types of stone, tile, and wood you can use, along with cheaper alternatives that can mimic those materials without breaking the bank. Two of the most popular alternative materials are luxury vinyl plank flooring, and stone polymer composite flooring: LVP and SPC. What’s the difference between them? And which is the best option for your home? Here’s a brief overview of these two flooring products.
What Are LVP and SPC?
Luxury vinyl planks are made of compressed layers of vinyl, with a high resolution image overlaid onto them, to mimic the look of another material. Planks are generally used to mimic hardwood, because the shape is similar to real wood planks. The high res image allows vinyl to look like virtually any other material, though, such as stone, tile, and more. LVP has several layers, but the main one is its vinyl core, which makes the planks durable but flexible.
Stone polymer composite flooring is similar, in that it includes a high resolution image, overlaid onto vinyl and coated with a transparent wear layer to protect the floor from scratches, stains, fading, etc. However, the core material in SPC is a hybrid of plastic and compressed limestone powder. This makes the planks hard and rigid, rather than soft and flexible.
The two materials are similar in many ways. They’re both waterproof, scratchproof, and generally fairly durable. They’re easy to install yourself, without the use of glues and solvents, and easy to maintain, with regular sweeping to get rid of dust, and a quick mop to get rid of spills. And they’re both significantly cheaper than the materials they’re acting as a substitute for.
The Differences
So, besides flexibility, what differences are there between the characteristics of LVP and SPC flooring? The rigid structure of SPC gives it a few advantages. While both can be installed over virtually any solid subfloor, LVP needs its subfloor to be completely level, and free of any dents, obstructions, etc. The flexible material will take on the shape of any imperfections, whereas SPC will keep its own shape, regardless of the floor below it.
By the same token, SPC is also more durable, resistant to dents and other damage. It will last longer, hold up better to wear. The rigidity of SPC also allows it to provide more support underfoot, while LVP’s pliability gives it a softer, more comfortable feel for walking on. SPC is also slightly thicker than LVP, and its look and texture tend to be a bit more realistic.
SPC has many advantages over LVP, but it does have one drawback. Its rigid, composite construction makes it more expensive than vinyl. While both are still cost-effective compared to wood, stone, or tile, if you’re on a tight budget, LVP is likely a better bet.
This is just a brief overview of the two flooring materials. There are plenty of other pros and cons of each, depending on your specific situation. So which flooring material is best for you? Talk to a flooring expert who can help you weigh the pros and cons of stone polymer composites vs. luxury vinyl planks, and decide which one best meets your home’s needs and can serve you in good stead for years to come.
The Advantages and Disadvantages of SPC Flooring
SPC flooring is becoming more and more popular thanks to all its remarkably desirable traits and features. However, how much do you really know about SPC flooring? Nothing is perfect in this world, it is no surprise that SPC flooring also carries some downsides with it.
It is only fair enough if you are made known of the pros and cons of SPC flooring before you join the SPC fanatic troop.
Here are the lists of SPC flooring pros and cons.
Rigid core luxury vinyl flooring, also known as SPC flooring, is the most durable waterproof vinyl flooring option on the market. It has a similar construction to WPC, but it comes with an ultra-tough core, which is where the name “rigid core” comes from.
So what does SPC stand for? As it turns out, it stands for a couple of terms that are used interchangeably: stone plastic composite or stone polymer composite. It refers to the make-up of the core. The SPC core is what makes this flooring so incredibly durable, maintaining its form even over uneven subfloors.
That means you can install SPC rigid core luxury vinyl flooring on any level, over almost any existing (hard surface) subfloor and for any amount of traffic.
WPC Flooring, SPC Flooring and LVT Flooring: What Differences, Similarities and Benefits?
If you own a modern home or have plans to own one in the future, you must have heard of vinyl floorings. These affordable and stylish flooring options are increasingly becoming the choice of many homeowners and commercial property owners who want to give their living and working spaces a fresh look.
There are three main types of vinyl flooring - WPC flooring, LVT flooring and SPC flooring. In terms of market entry, traditional versions of Luxury Vinyl Tile flooring have been in the market for many years. With time, changes in buyer preferences led to the development of advanced flooring solutions that saw rigid core vinyl such as WPC and SPC flooring hit the market.
Even so, each flooring type comes with its own set of benefits and drawbacks that you need to consider before settling for one. Though different, the three flooring types share several similarities.
In this article, we explore the benefits, differences and similarities that SPC Vinyl flooring, LVT and WPC floorings have.
Before we delve into this, let's first define each of these vinyl flooring:
LVT Flooring
Luxury Vinyl Tile is an updated and innovative version of vinyl flooring that is today a top contender when it comes to floor installations in commercial and living spaces. Designed with a real wood, stone or ceramic look, LVT flooring is not just affordable, it is also durable, waterproof and resistant to scratches.
SPC Flooring
Stone Plastic Composite (SPC flooring), also referred to as Rigid Vinyl Plank, is an upgrade of LVT. SPC vinyl flooring comes with multiple layers and backing options that make it ideal for homes. Some key aspects that make it stand out include low noise levels, no warping, eco-friendliness and insulation against sound and heat.
WPC Flooring
Wood Plastic Composite (WPC) derives its name from the wood-like material used to make it. These materials include a foaming agent known as polyvinyl chloride, plasticisers, wood flour and calcium carbonate.
What does Embossed Vinyl Flooring Mean
As you explore the many flooring options available for your home, you may be focused on finding a beautiful material that enhances the décor. Real hardwood flooring is a popular option because of its undeniable charm and wide range of available styles. Many people love the texture of the grain of the wood as well as its richness and sheen. From the sophisticate of deep cherry wood with a smooth sheen to the deep striations and character of oak floors with a textured finish, there is a wood flooring style that is seemingly perfect for most homes. However, wood flooring as its drawbacks. For example, it may easily be scratched, and it should not be exposed to moisture. In addition, it may be one of the more expensive flooring options available. If you are looking for a great alternative to real hardwood flooring without the drawbacks, embossed vinyl flooring or laminate flooring mimics the grain of the wood and may be a more suitable option for your home.
Before you learn about embossed vinyl and laminate flooring, it makes sense to understand how vinyl floors and laminate planks are different than hardwood flooring. These are both synthetic flooring materials that are known for their affordability and durability. Vinyl is usually comprised of a PVC material, and it can be texturized and dyed to mimic the look of many other types of floors. Regardless of whether you choose embossed vinyl planks or tiles, floating vinyl or glue installation methods are available.
Laminate flooring, on the other hand, is comprised of multiple layers of a wood material compressed tightly together. This material is usually fiber board or a type of melamine resin. It is covered with a printed layer that can mimic the look of wood flooring. Laminate also has a wear layer, which could have a textured finish or a smooth finish. It is most commonly available in laminate planks, but you can find tiles as well. The same installation methods that are available for vinyl flooring are available for laminate flooring.
How to Estimate T-Bar Ceilings
T-bar ceilings, also known as acoustical ceilings, usually are installed to hide overhead ducts and pipes in basements. In other cases, t-bar ceilings in kitchens have flush overhead lighting and water-resistant ceiling tiles. T-bar ceilings consist of a metal grid and ceiling tiles. Taking a few measurements and deciding on the size of the tiles allows you to estimate the cost of materials and installation.
Determine the square footage of the T-bar ceiling. To do this, measure the length and width of the room and multiply one by the other. In other words, if the room is 20 feet long and 14 feet wide, the square footage is 280 feet. If a measurement isn't exact to a foot, round it up to the next foot.
Determine the square footage of ceiling tiles based on the square footage of the ceiling. Acoustic ceiling tiles are sold by the square foot in packages that contain eight tiles. The number of packages is not particularly relevant, as long as the square footage is determined.
Determine the size of the tiles, such as 24-inch square or 24-by-48-inches. If the larger tiles are a preference, determine the direction they will install, such as perpendicular to the long walls or running in the same direction. With this determined, proceed with estimating the grid.
