#22969
The over/under odds provided by bookmakers are quite diverse, with many choices for bettors to increase fairness in their games. So, have you understood the over/under odds and how to read the details of these odds? Check out this article to easily choose odds when participating in online football betting.
Stay ahead of the game with our best paid soccer tips
What are over/under odds?
Over/under odds are the predicted figures provided by football betting sites, also known as odds. Depending on the match, bookmakers will offer different over/under odds. Even in the same football match, bookmakers can provide 3 to 4 types of over/under odds. This is because bookmakers provide players with multiple betting options, and all these odds are calculated very accurately.
How to read over/under football odds
Below is a summary of how to read over/under odds in the current football betting sheet.
Over/under 0.25
Over 0.25 is a very low over/under odds, so it will only appear in the first half of the match. This odds will usually appear in tense matches where both teams have poor attacking performance.
The rule for calculating the odds is as follows:
If both teams score at least one goal within the specified time, Over bets will win the full bet.
If both teams do not score any goals within the specified time for odds calculation, those who choose Under will win half the bet, and those who choose Over will lose half the bet.
Over/under 0.5
Over/under 0.5 odds will usually appear in the first half of the match or in a final match where both teams are highly practical.
The rules and odds calculation are as follows:
If both teams score at least one goal within the specified time, those who choose Over will win the full bet.
If both teams do not score any goals within the specified time for odds calculation, those who choose Under will win the full bet, and those who choose Over will lose the full bet.
Over/under 0.75
In reality, 0.75 is still a relatively low total goals odds. Therefore, similar to the two over/under odds mentioned above, over/under 0.75 odds will usually only appear in the first half of the match.
If both teams score at least 2 goals in the specified time, those who choose Over will win the full bet.
If the total number of goals scored by both teams within the specified time is 1, those who choose Under will win half the bet, and those who choose Over will win half the bet.
If both teams do not score any goals within the specified time, those who choose Under will win the full bet, and those who choose Over will lose the full bet.
Over/under 1
Over/under 1 is very popular in football betting. These odds can appear in both the first half and second half of the match. However, if it appears in the first half, it indicates a high likelihood of many goals being scored. Conversely, if it appears for the entire match, the match may be very dull.
If both teams score at least 2 goals, those who choose Over will win the full bet.
If both teams score only 1 goal, whether you choose Over or Under, it's a draw, and the bookmaker will return your bet.
If the match ends with a score of 0-0 within the specified time, those who choose Under will win the full bet, and those who choose Over will lose the full bet.
In addition to these over/under odds, bookmakers also allow players to bet with different over/under odds. The rules are similarly straightforward and are somewhat similar to the over/under odds mentioned above. Over/under odds are often found on the bookmakers' betting sheets, including:
Unlock your winning potential with our betting tips vip app
Over/Under 1.5
This type of odds is often presented by bookmakers in intense and hard-to-predict matches.
Here's how to read them:
If the total number of goals scored is greater than 1, the Over bet wins.
If the total number of goals is 1 or 0, the Over bet loses, and the Under bet wins.
Over/Under 1.75 or 1.5/2
Specifically, the reading goes as follows:
If the total number of goals scored is greater than 2, the Over bet wins.
If the total number of goals scored is 2, the Over bet wins half, and the Under bet loses half.
If the total number of goals scored is less than 2, the Under bet wins.
Over/Under 2
For these odds, the reading is as follows:
If the total number of goals is 2, regardless of the bet, it's a push, and your bet is refunded.
Over/Under 2.5
This is the most common Over/Under odds and very straightforward to read:
If the total number of goals scored is 3 or more, those who bet on the Over win.
If the match has only 2 goals or fewer, betting on the Over will result in a full loss.
Over/Under 2.5/3 or 2.75
The reading for these odds is somewhat complex, similar to 2.25 odds:
If the total number of goals scored is 4 or more, the Over bet wins.
If the total number of goals is 3, the Over bet wins half, and the Under bet loses half.
If the total number of goals scored is 2 or fewer, the Under bet wins.
Total Goals Over/Under
In these Over/Under total goals bets, players can choose from 8-16 options offered by bookmakers, with odds ranging from 0.5, 1, 1.5 to 7.5, 8, and so on.
This type of bet opens up the opportunity for players to choose unlikely odds with the potential for high winnings or low winnings. It also allows for low-risk bets with the chance to win big or secure small winnings.
For example, if the final score of the match is 0-2, betting on the 1.5 and 0.5 Over will win. Similarly, betting on the 7.5, 6.5, 5.5, 4.5, 3.5, and 2.5 Under will win, while other bets will lose.
If the final score is 2-5, bets on the 0.5, 1.5, 2.5, 3.5, 4.5, 5.5, and 6.5 Over will win, and the rest will lose.
See more betting tips at : what is an asian handicap in soccer
In addition to total goals, reputable bookmakers offer various other Over/Under bets, such as corners, fouls, and penalties. You can also combine Over/Under bets with other types of wagers; these are referred to as combination bets.
SevenFriday replica watches
SEVENFRIDAY M3/01 Spaceship Edition SEVENFRIDA[…]
replica Greubel Forsey Balancier Convexe S²[…]
